Pump NPSH calculation spreadsheets or web sites
what is the best pump calculation web site or spreadsheet you ever have come over? Please send it! It has to contain the possibility of pressure drop calculation for inlet and outlet piping
RE: Pump NPSH calculation spreadsheets or web sites
there are many websites available for your choosing to assist you with your needs.
good luck!
-pmover
like pmover the best spreadsheets I have are the ones I have prepared specifically for my needs. All the methodology you need is described on the above:
In the offshore engineering business e.g Crane calculation spreadsheet can be used for that part.
What I sought for was a spreadsheet like Crane that as well included the NPSH calculation.
Perhaps you could consider putting a hyperlink to the following website into your spreadsheet.
ht
Regards, Gunnar
regards runsaep
from Norway - like you?
