NO BACKGROUND COLOR WHILE PRINTING?
Does anyone know of a way to print in Pro E 2.0 without the background color,of course,without changing the background color.Maybe a config file that excludes background color during printing.
RE: NO BACKGROUND COLOR WHILE PRINTING?
Change in config file is applyies to all instead
change the BG color in simple step and take the print and change back it to intial position.
views>display settings>system color>scheme>black on white.
views>display settings>system color>scheme>intial. - to revert back to intial coloring.
In this way, there is no change of the bg color manually adjusting the color pallete.
easiest just to change schemes, but you can actually change the color of background from the graphics tab... by unchecking blended background and then clicking on the background icon and moving all the slider bars over to far right
personally I'd go with the scheme... you could even mapkey it, to make it all happen auto-magically winky smile
you can make your part disappear completely if your geometry is set to white ...
