AutoCAD to MicroStation Global Scale Issue
I have a project in MicroStation and I am referencing both dgn and AutoCAD dwg.  My coordinates are correct for my dgn and are correct in my dwg but only when i open my dwg in CAD.  In MicroStation, dwg coordinates are correct but my units are set to metric.  If i change units to feet and save as a dgn, my coordiates have now jumped and scaled by the conversion 3.280829065 (number of feet per meter).  How do i save as and keep my coordiates in their appropriate location and keep my units to feet?  i have set my units in CAD to feet and in Microstaion.
RE: AutoCAD to MicroStation Global Scale Issue
I have had a similar problem with microstation defaulting to metric when referencing .dwg files.  The work around that I have used is to attach the .dwg, then turn off true scale.  At this point, your reference scale should go from 1:1 to 3.2808 to 1.  Change the scale back to 1:1 and the reference should come in at the right scale and at the right coordinates.
