Density of lead sludge
Assuming that there is constant inlet of water containing Pb particles into settling tank, water on the outlet is clear (all Pb particles remain in tank), and there is no slurry outlet, I need to estimate volume of lead slurry on the bottom, after certain amount of time.
For that I need to calculate or estimate density of lead (Pb) slurry on the bottom of settling tank.
Is that possible?
Thanks for any help,
Paul
Is that possible?
Paul
RE: Density of lead sludge
I presume that you will periodically open the sludge drain and allow it to flow out of the bottom.
In that case, you can monitor the slurry in the underflow and close the drain valve when the density drops to that of the incoming slurry and automatically open the valve on a timer.
Alternatively, assuming a clean tank start, a volume flow meter on the inlet flow and a density meter in the inlet flow recording %mass or % volume of lead particles, you should be able to run a mass or volume total for the lead and alarm when it reaches a pre-set amount.
JMW
www.ViscoAnalyser.com
