"Internal Error: Memory Access Violation" with UDFs
Hi!
I'm working with Knowledge Fusion, and I want to load a UDF from a *.dfa file, I think that the sintax is ok, but sometimes when execute the file N.X.4 gives Internal Error: Memory Access Violation.
I don't know which is the problem because sometimes it run ok.
Can someone help me?
(child)  udf:
    Class;            ug_udfs;
    Name;            "udf_name";
    Parameters;        {{},{}...};
    References;            {{},{}...};
Thank you,
and sorry about me english.
RE: "Internal Error: Memory Access Violation" with UDFs
What version of NX4 are you running?  We had failure issues with UDFs with 4.0.3.3 that required us to move to 4.0.4.2 MP3.
Before I had 4.0.0.25 but now I have moved to NX 4.0.4.2 (which I think is the last) and the problem continues
How do you references the UDFs fron the *.dfa file, I think that the problem is with the references, because I have some UDFs that don't nedd references and its run ok.
Thank you
