Convective Heat Transfer
I am setting up a convective heat transfer interaction in abaqus. My model has a flat Alumina surface at a certain temperature (greater than ambient temp) exposed to atmosphere. I am not sure as to
1. what value to input for the Film Coeffecient (Flat Alumina surface)
2. What expression should I use in the Expression Field. Is this expression merely the direction in which the convection takes place? Please help. Thanks
RE: Convective Heat Transfer
corus
