Process engineer duties in T&I
Hi folks, i am a chemical engineer working in the oil industry, currently running without much guidance in the process engineering department. What i need is a checklist and if possible brief explanation of what the duties of a process engineer during turnaround and inspections are, i will be focusing on Delayed cokers (including fractionation column) and HDT.
RE: Process engineer duties in T&I
For your own good, I believe that should come from your boss, and not an engineering forum.  Then, if you have any questions on how to achieve those tasks, we can help.
Good luck,
Latexman
You might want to check w/ the manufacturer...  Thye usually have good info....
