PDMWorks Workgroup
PDMWorks Workgroup
Hi all,
We finally got our upgraged to SW Pro and have a PDMWorks question. How do get PDMworks to work within the SW session? It was in the addin's a few versions back, but can't find to add in the toolbar. PDMworks works when I open SW Explorer, but can't get to run with SW.
Macduff ![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Mechanical Design Engineer
Solidworks 2007 SP 4.0
Dell 390 XP Pro SP 2
Intel 2 Duo Core, 2GB RAM
nVida Quadro FX 3450 512 MB
RE: PDMWorks Workgroup
After that, it'll be in the flyout on the right side.
Jeff Mirisola, CSWP
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Macduff![[spin] spin](https://www.tipmaster.com/images/spin.gif)
Colin Fitzpatrick
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Colin Fitzpatrick
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Have a good day,
Colin Fitzpatrick
Solidworks 2007 SP 5.0
IT doesn't know the difference when they install, I'm guessing. You may wish to let them know, or do the proper thing and take control of software installations for engineering tools out of their hands. :)
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
A star for you. I was telling IT about the "Other Tool" button, and how PDMWorks was inside there and need to install it. This comfirms my statement, and will pass this thread onto them.
I wish I could take control, but won't happen here sir.
Have a good T-day everyone.
Colin Fitzpatrick
Try this fisrt... Go to the add remove programs under the control panel and find the SolidWorks Explorer entry. Click on it and click change. This will go through the install process. Under add/remove components add the PDMWorks Plug-in. I seem to remember the PDMWorks plug-in not installing at first, so this had to be done. Not exactly obvious to the end users.
Pete
You are right, sometimes. This solution doesn't always work. I've guessed this is so because SolidWorks may have been originally installed from an image file that wasn't configured properly to begin with (didn't include PDMWorks Add-in when creating the image file). Either way, because this doesn't always work, I default to just using the method I listed above.
Matt Lorono
Silicon Valley, CA
Do I need the DVD for this? The IT guy is out till after T-day. I don't want to mess around and find out that I need the disk or somthing.
Thank,
Colin Fitzpatrick
Matt Lorono
Silicon Valley, CA
Colin Fitzpatrick
When you get hold of the DVD, copy it to a folder on your machine. Then when the install asks for the DVD you should be able to re-direct it to the folder.
But the better way would be to have IT add the correct scripting to the Admin Image.
https://w
Colin Fitzpatrick
