making parameters bystronic
Hello
Can someone tell how you make parameters to cut would and glass, and if possible coper
RE: making parameters bystronic
0.5 to 1 bar. this is very approx but will get you going
depending on the thickness & type your trying to cut.
the most important thing to remember is if you do not have
the foot type height sensor you must turn off height detection
in set up otherwise the z axis will crash into the sheet at high speed. We cut wood and adjust the height manually.
I could email parameters for a byspeed 4.4 if required
You should also have an operator at the machine at all times
when cutting wood.
Steve
if you could send me the paramaeter.
you could send it to kimielco@hotmail.com
