MSD Development
MSD Development
All:
I am trying to develop MSD's from available PFD's. Right now we do not have equipment datasheets,We only have pipespecs available, would that information be enough for the MSD's.
What other information do I need?
Any help would be appreciated?
npf
npf
RE: MSD Development
I forgot to add, I have Material Selection Design Basis Document available listing matieral requirements for key equipment items.
npf
RE: MSD Development
The important thing is that this document explain clearly what are the assumption, calculation, standard, and the criteria adopted to select the material for at least the main stream and item of your plant.
I've seen sometimes people that develop P&IDs without a Material Selection Report and discover that they have to change all the materials.
So, this is my suggestion,before you start develop anything be sure that you have a "solid" document produced by someone with experience in Corrosion & Materials Selection.
S.
http://www.corrosionist.com
RE: MSD Development
https://
Steve Jones
http://www.pdo.co.om/pdoweb/
RE: MSD Development
