Transpose direction of line in ACAD?
Long time Microstation user trying to figure out how to change the direction of a line in ACAD without redrawing the darn thing.
Any help is appreciated.
RE: Transpose direction of line in ACAD?
Rotate it 180 degrees about its midpoint - use the rotate command: select the line, for basepoint use object snap to select the midpoint, then rotate 180 degrees.
