Access Violations
Access Violations
Access Violations
Is there a system to all the references and numbers we experience with Access Violations and Exceptions - what do they all mean?
Cheers. Sean.
RE: Access Violations
Hi SeanSweeney,
Not per se, but if you check Autodesk's support, and search on your violation number, once in a while you'll get a hit - not very often though...
HTH
Todd
Sometimes, you can Google an error code, especially when you place it in quotations, and find others discussing similar problems and maybe finding a solution.
Don Phillips
http://worthingtonengineering.com
Thanks guys.
Cheers. Sean.
