Calculating surface area?
HELP --- Is there a way to calculate the surface area of an assembly? For example I am assembling three layers - two flat plates of a different thichness that sandwich a layer of bricks. When I try to use Model Analysis the value the I get is the surface area of all three layers as if they were separate. I am trying to determine the surface area of all three assembled for painting.
Thanks;
Dad1
RE: Calculating surface area?
You can do a few things.
1-Make a shrinkwrap of all the parts and measure the shrinkwrap.
2-Make a surface envelope of the assembly and measure that.
Hope this helps.
http://www.3dlogix.com
