Solidworks 2007 Pro Dimensioning
Dear Folks;
Heres a simple problem. I have a SW 2007 Pro SP 0 drawing with the units set to feet and inches. In one section view, when I add dimensions I get decimal dimensions. Even if I right click properties and try to change the units to feet and inches, the dimension stays as a decimal. Other dimensions in the view however, behave as expected and display feet and inches.
I've gone back to the .sldasm file and made sure units are feet and inches, and also with the .sldprt files.
Any suggestions would be much appreciated
Adrian Dunevein
AAA Drafting Services
www.aaadrafting.com
http://home.cogeco.ca/~adunevein/
SW2006 Office Pro. SP4.1
RE: Solidworks 2007 Pro Dimensioning
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
The rounding option was unchecked
Many thanks Cor Blimey
Thanks Scott as well but I had already checked the unit properties.
Adrian Dunevein
www.aaadrafting.com
