Carbon Steel Flange for class API5000
As per API 6A and ASTM A105 standard, carbon steel A105 cannot be used for class API5000.
However, when I saw some piping specification, it specified carbon steel A105 for pipe wall thickness less than 1". Also I found many carbon steel flowlines using A105 flange when connected to X'mas tree.
Anyone can tell me about this?
Thank you very much.
RE: Carbon Steel Flange for class API5000
I have seen this often accompanied with the appropriate spec break on the P&ID.   This was done where the API flanges would mate up with ASME Class 900 or Class 1500 RTJ flanges.
