SPI, circuit board routing
Hello-
Im converting an MCU<->MCU interface from I2C to SPI. Problem is, the MCUs are on different PCBs- where one is on a daughter card connected via standard IDC Header/socket. The trace length is minimal- 6" or so. But, I have no experience with routing high-speed signal lines; the I2C version works well (electrically, anyway), but that is at 100khz clock.
Aside from the standard guidlines on EMF/ground planes, can anyone provide me any guidance on dos and donts regarding this type of signal path? That is, are vias OK? Will an IDC header/socket support SPI signaling without horrible reflections, etc? Since this header is effectively the same as is used in a PC IDE motherboard, and since an IDE interface is running with a clock of at least 8Mhz, Im hoping SPI is not a big deal in terms of routing.
Any guidance is appreciated-
R
R
RE: SPI, circuit board routing
SPI has speed limits too. What speed are you planning to use? Hint: Use the slowest that will serve your needs.
Keith Cress
Dan - Owner
http://www.Hi-TecDesigns.com
Keith Cress
Thanks for the responses. Im not really 'anti-I2C,' it has worked for me in the past. But clearing the bus can be a pain, and it seems that the interface to most support devices Im looking to implement (FPGAs, Flash, EEProms, etc) is SPI (presumably, a speed thing, but maybe a royalty thing also??).
On clock rate, I dont really need much more than 100Khz, but I think my fastest devices are 2Mhz-capable. So, if I can approach 1-2Mhz, that will free up bus time. Unfortunately, with PICs anyway, you have such limited RAM that the concept of 'bursting' data is prety silly; at most I have 1K RAM available, so my ability to store and forward tons of data is limited.
Here is an added problem though- I have some daughter cards that are I2C-based. So, at least for development, it would be better to have the main bus be I2C and SPI capable. For the PIC, this means external pullups on SDA/SCL. Since those pins are multiplexed with SDI/SCK, Im wondering if those pullups will screw up the SPI comms? On my dev board, with pullups enabled, SPI seems to work just fine- but I cant find any spec from Microchip on the internals of their SPI module (if it is push/pull, open drain, etc), so this remains another unknown. You guys have any ideas?
And on rise/fall times, is this mostly a function of keeping trace length and capacitance down? I have some docs on USB routing- and presumably the rules are similar- but I expect that the clock rise/fall time with SPI is a different animal.
Rob
The pullups won't be a problem either. Rise and fall times will not be an issue with those PIC pins. Nor will the connector.
Have at it.
Keith Cress
Much appreciated on all the feedback- now if I could just figure out why SPI-based SD storage is so slow! Ugh.
Rob
