Lateral frame question
Does the 2006 IBC or current AISC restrict the use of knee brace frames?  I think I've seen comments on KBMRF's before, but did not know if they are disallowed now.  Any direction to technical info for this would be appreciated.
RE: Lateral frame question
I did find a commentary about these on page 6.1-170 under C11.1 for OMF's.  Anyone out there actually design under these stipulations?
That would be in the 2006 AISC Seismic Design Manual...
How much effective these are as compared to moment frames not considering the cost issue.
In Chapter C, "Stability Analysis and Design", section 3a on page 16.1-20 there is a shaded user note you might be interested in:
"Knee-braced frames function as moment-frame systems and should be treated as indicated in Section C1.3b.  Eccentrically braced frame systems function as combined systems and should be treated as indicated in Section C1.3d."
I assume your question pertained to steel structures, for, as far as I know, there is no restriction to the use of Knee braces for wood construction, be it porches, pole structures and the like.
Mike McCann
McCann Engineering
