When is a reduced port ball valve a better choice?
Having been in the industry over 8 years, I'm almost embarrassed to ask, but it's something that been bugging me:
Considering that pressure/energy loss is almost always undesirable, and the fact that they're not easily pigged, why and under what circumstances would a reduced port ball valve ever be a better choice than a full port valve?
A well defined problem is half solved.
RE: When is a reduced port ball valve a better choice?
Thanks for providing some applications where reduced port ball valves are commonly used. I can understand how the reduced port style might be less expensive in smaller sizes, especially if the manufacturers are using the same casting for both types of balls and simply machining a larger bore in those that will be sold as full port. However, my catalogues list reduced port valves up to 42". I would think that in larger sizes... say 12" and up, manufacturers would save money by using two different castings (one for boring full ports, one for boring reduced ports), thereby saving on initial material and subsequent machining costs?
But manufacturers' costs aside, I still don't understand when a reduced port ball valve would be a better choice than a full port valve. That is, under what circumstances would one want to achieve pressure/energy loss and restriction of flow with a ball valve when a simple (and less expensive) venturi device would affect the same results? What am I missing here?
venturi.And ball valves are not only for control thay are used as block valves also (very often in gas service).
Now considering cost sensitive general services such in HVAC chilled water, city water, instrument air systems, etc. where many decades ago, used globe valves (high pressure drop, but tight shut-off) or suffered with leaking gate valves (low pressure drop, but leaked), the cost and performance benefits of using reduced bore ball valves was huge.
Because of the cost difference, significantly more reduced port valves are sold than full port (by a factor of around 3:1). This fact says a majority of valve applications can live with the increased pressure drop.
I hope this helps end an 8 year dilemna.
Wow! What an excellent explanation. You've not only clarified a long standing question I've had, in doing so you've also enabled me to be better at my job.
Although 80% of the ball valves I spec' and purchase must be piggable and minimize energy loss, the cost savings of installing reduced port valves, where those qualities are not decisive factors, will be considerable.
I guess the root of my misperception was assuming that the two styles shared common balls, differing only in their bores. Your thorough explanation makes perfect sense.
I guess I could've called a manufacturer, but it's like the old story where a guy is frantically and laboriously sawing down a tree, and it's taking all day. Another guy walks up, watches awhile and tells him he'd have a much easier time if he's sharpen the saw. The first guy replies, "I'd like to sharpen my saw, but I'm too busy sawing."
Anyway, thanks again bcd, and everyone else who took the time to help me sharpen my saw.
