Creating a watermark in SW2008
Has anyone tried making their own watermark in SW2008.
You know something that would go across the drawing that would say DRAFT or something.  I print on a BW laser printer but everything seems to come out black.  I haven't tried printing in grayscale yet.
"Perfection - a result of many mistakes."
Blair H.
SW 2007 sp2.0, HP x6400, 2.0ghz dual core xeon, 2.0 GB ram, Nvidia Quadro FX 1500
RE: Creating a watermark in SW2008
I've done that before. We used Grayscale or maybe the line weight.
We had the Watermark on a layer called...you guessed it...Watermark. And the text was actually in the Title Block template. The releasing routine would turn off that layer and add the appropriate text/stamps/blocks/etc... Most of the users didn't even know that it was just a layer that they themselves could turn off and on, so we didn't have to worry about them printing off any un-approved drawings and trying to get parts made from them.
Ken
Under your line formats toolbar there is a "color mode" selection you could try toggling that giving it a color. It will effect the entire drawing mind you, but you can control the colors on those as well.
Scott Baugh, CSWP pc2
www.scottjbaugh.com
Quote:
"If it's not broke, Don't fix it!"
