Heat output from phase converter
We need to know the cooling requirements for an equipment room with an Arco Roto Phase phase converter.  The model number is CHDELV10.
Anybody have specs?  Or any rules of thumb for the amount of BTUs put off by this machine.
Thank you.
RE: Heat output from phase converter
If no one does.. Maybe you can measure it.
Keith Cress
I would think Arco would, no? UL testing requirements for the electrical equipment they sell would require they know that.
I do not know the specifics, but power in minus power out from the rating plate should give you some idea.
Warpspeeds answer is right on the money.
I'm not sure that this is really the forum for this sort of thread though
