SWMM5 EXAMPLE
SWMM5 EXAMPLE
hi everybody
does anyone know where can i find example applications and samples for getting more familier about this software and procedures? i have already downloaded its manual but i need more practical samples
RE: SWMM5 EXAMPLE
First, go to "Help" and click on "Tutorial".
There are 3 tutorial examples that come with the SWMM5 package. These are installed with the software application. Look for the "*.INP" files.
You can also download 20 input files from the SWMM W3 site. These are included in the "epaswmm5_qa.zip" file, described as "Quality Assurance report for dynamic wave flow routing" on the W3 site.
You can also see examples posted at ENG-TIPS such as"Small culvert feeds into larger - how to calculate profile" (thread194-200519: Small culvert feeds into larger - how to calculate profile, http://www
There is a page at Duke University with downloadable files (http://medina.cee.duke.edu/Stormw/index_dwn.html). There are others online at various universities.
SWMM4.x files can be converted to SWMM5 files and used as well. Try some W3 searches for input files and you should get some hits. See "http://eng.odu.edu/cee/resources/model/swmm.shtml" for various SWMM resources.
Let me know if you need more sources.
tsgrue: site engineering, stormwater
management, landscape design, ecosystem
rehabilitation, mathematical simulation
http://hhwq.blogspot.com
RE: SWMM5 EXAMPLE
RE: SWMM5 EXAMPLE
I suggest looking through the links/files I posted above and going through the tutorials/examples. Several of these have ponds and/or storage nodes.
The pond routing is fairly straightforward.
The help in SWMM5 is "context sensitive". When you are in the storage node windows, clicking help will bring up help on that portion of the application.
The best way to learn the application is to take a few hours to run through the tutorial and look through the examples. Once you do this, I think you will have a "feel" for the system and will be able to start applying it to a variety of applications.
If you need further, post again and let me know.
RE: SWMM5 EXAMPLE
I didn't see a pond scenario in the tutorials, just a storm network. I'm mostly interested in how do model the outlet structure. I want to use an outlet node from a storage unit to model a riser/barrel structure from a pond. However, SWMM wants a rating curve either in the form of a defining function or a table. I could certainly generate this curve in terms of driving head vs. outflow, but wouldn’t the rating curve change based on the downstream conditions (i.e., backwater)? That is, if my outlet pipe is submerged, my rating curve will be invalid, correct?
RE: SWMM5 EXAMPLE
You can model a pond with a storage node and junctions/outlet, storage node and junctions/pipes, storage node and weir/orifice, channel and junctions/pipes, or some other combination. You can use a divider if needed, depending upon routing method (dynamic/kinematic). If you use a rating curve, SWMM will process this to allow the "most limiting flow" to drive the system. Your rating curve is invalid only if the rating curve incorporates the tailwater condition. I know that sounds backwards, but the tailwater condition needs to function independently of the riser/barrel (weir/orifice/pipe) of the pond outlet structure - so you have that defined separately by the downstream channel/condition. Try this out and post again if this doesn't make sense or you try and need further help. Please attach your *.inp file with any post.
(I really thought one or more pond examples were included.)
Hope this helps.
RE: SWMM5 EXAMPLE
