Tips on replacing an old Brook Slip ring
Hi Guys,
Can you give ma any tips on replacing an old Brook Slip ring 60Hp 6 pole 63 amp Rotor current, 78 amp Stator current, Ac Motor. This motor is on a small crusher originally used for crushing stone but now used as part of a re-cycling process where it crushes 4" concrete blocks. The new load is not as demanding as the machine was intended for, but I want to stay with a similar rated new Ac standard Motor. I was thinking of using a 55Kw 6pl 400V std motor with a 160Kw Soft start. Can you give me a guide as to the best way to replace this old motor.
Thank You.
Thank You.
RE: Tips on replacing an old Brook Slip ring
http://www.baldor.com/pdf/manuals/PR2525.pdf
Under "Glossary of Motor Terms" look at Design
Do not confuse the Design letter with the code letter.
You may consider a design "D" or design "C", depending on your load.
For rocks you would probably want a design "D". For concrete blocks you may be able to use a design "C".
respectfully
