Solidworks Sketch Dimension not highlighting
So when I click on whatever geometry I just drew and go to define it in a sketch, my sketch does not highlight when I select it. I dont know how this property got changed but does anyone know how I might be able to change it back? Its really annoying not knowing what you are selecting! Thanks for your help!! :)
RE: Solidworks Sketch Dimension not highlighting
Sounds like a graphics card issue to me.
Can you be a little more clear? Are you trying to say that when you select a sketch entity it doesn't highlight? Or, are you trying to say that when you select a sketch from the FM it doesn't highlight? Or, are you trying to say that when you select the geometry, it doesn't highlight in the FM?
Now I've gone and confused myself.
Jeff Mirisola, CSWP
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
When I go to click on the sketch entity it doesnt highlight. Sorry bout that.
Bernie
Just out of curiosity, the sketch is still active when you select the entity, right?
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Yup
Assuming that you haven't recently changed service packs, I would update to the most recent one. If you're already there, have you updated your graphics card driver lately? If so, then you should roll back to the previous driver.
If neither of those two situations are valid, then how do you feel about messing around in your registry?
Jeff Mirisola, CSWP
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Turn on the software OpenGL and see if the problem persists.  If it goes away, you have a graphics card / driver issue.
Eric
Tools>>options>>system options>>display/selection>> dynamic highlight from graphics view
Joe
SW Office 2006 SP5.1
P4 3.0Ghz 1GB
ATI FireGL X1
