MFLUIF CARD
MFLUIF CARD
Hi Everybody!
We're having a doubt about MFLUID CARD. You define in it the Coordinate system and the position(along Z axis of this CS) of the free surface of the fluid (ZFS: every element which is below ZFS is wetted).
If ZFS=blank, the default value is ZFS=infinite. My question is if, in this case, the fluid extend also along negative values of Z or just along positive values of Z.
Thanks very much
Enrique
Thanks very much
Enrique
