What's the range of friction factor between steel and concrete?
  I met a problem,which needs to know the friction factor between steel and concrete. I used 0.4, but someone said it's the maximum value and not saft for calculation.So I wonder the range. Does anyone know it?
Thank you!
Rock Li
RE: What's the range of friction factor between steel and concrete?
I used to hear about it: somebody here in Italy make the assumption that the contact is similar to steel-to-sanded-steel, i.e. 0.3 (following old norm UNI-ISO 10011, for example). I know nothing more precise.
