Down hole corrosion of GRP lined pipe
In the field 7" GRP pipe is used, we are doing corrosion tests simulating this pipe. We are using 3.5" pipe. Would you foresee scalability issues? If so what would they be?
RE: Down hole corrosion of GRP lined pipe
