Vaccum sealing arrangement in valves
Can anybody please clarify "Vaccum sealing arrangement in valves".
Vaccum sealing arrangement in valvesVaccum sealing arrangement in valves(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Vaccum sealing arrangement in valves
In such case, differential pressure is reversed. You shall insure your valve sealing arrangement works in reverse way too. It is not the case for lip seals or chevron type seals.
Particular care shall be also considered with O'rings in high pressure designs.
For standard Gate valve, I don't see any problem as far as packing is design for.
Can you please clarify water sealing arrangement requirement in gate, globe valves
In addition, a "lantern ring" may be used to prevent air leakage through the stem packing. The "lantern ring" also requires a water supply.
In the past, there is Royal-Dutch SHELL MESC specification for vacuum service. Afterward, the end-user expired this specification since the most of gland packing/ seal can withstand reverse pressure, i.e. from atomospheric to valve internal in vacuum condition. Unless otherwise the external pressure of the valve is higher than atomospheric, I think this reference can be applicable to your situation.
If your situation is more complicate, I would adivse you to tell members more details of application. Perhaps, I can check more concrete condition to close to your expectation.
Best regards,
Can you suggest vendors who can offer sealing water arrangement for Gate/ Globe valves
