Non linear analysis: Solution no converged
I am doing a finite element analysis of a lamitated retention system. I have created a blade (roughly a 0.5mm sheet of metal) and I want to twist it along its longitunal axis with a displacment value equal to 6°. Consequently, I tried to do a non linear analysis since we have large deflections (rotation in our case. I tried several shell element type to mesh the blade, but each time the solution unconverged and the result qare really stranged.
Can you help me to find the reasons of this unconverged solution?
Thank you for your help,
Mickaël
Mickaël
RE: Non linear analysis: Solution no converged
-Active nlgeom, on: Includes large-deflection effects
-Increase nsubst : the number of substeps
-Change the CUTCONTROL
hope that help you!
Mickaël
Garry
