Postprocessing Reactions
Does anyone know how to edit reaction information in the postprocessign mode of STAAD?  I want to only show vertical or horizontal reactions and remove the moments.
RE: Postprocessing Reactions
In the post-processor, select all of the nodes, select "Support Reactions" in the reports menu. When the reactions are displayed, click on the upper left corner block labeled "Node". This selects the entire table. Now press Ctrl-C to copy it to the clipboard. Open Excel and paste it into a blank spreadsheet. Everything will be copied into separate columns. Now you can delete the columns that you don't want.
