polyethylene fouling
I have a reactor that gradually fouls with polyethylene. This is a low density low MW PE. I flush the reactor with a hot isoparaffinic solvent to remove most of the PE. Is there a better way to get it clean? I imagine aromatic or naphthenic solvents would be best, does pressure play a role?
RE: polyethylene fouling
also, find out why the reactor fouls, so you don't have to clean.  study CO2 inhibitors.
Thank you, I understand that I could stop it with Co2, but I would also kill the reaction I am running. CO2, in this instance is not an option. Are there any other ideas out there. Thanks
