Bolt with thread near head
   I am looking for a bolt which is partially threaded but the threaded portion should be near the head of the bolt and the unthreaded portion towards the open end. The bolt size should be 5/16"-18 Grade 8 x 1/2" Long. I tried searching a lot but did not come across such a bolt. Can anyone suggest a blot or anything else which matches this description?
David Landis
RE: Bolt with thread near head
Is this a joke?  How would you start the nut with the unthreaded portion at the end opposite the head?  Seriously, a 5/16 x 1/2 bolt will be fully threaded.  Why don't you draw up what you want and give a machinist a laugh.
I think you want a dog-point tap bolt. Call your bolt supplier. You can definitely get it in a square head which is a setscrew, you might be able to get a hex head. Start looking.
That dog point is similar to the ends of lugs on wheels and used to aid assembly.  If you don't need a high quantity you could have a machine shop modify a few standard bolts.
Business Page   http://mech.e.tripod.com
Motorradtraum....www.tailofthedragon.com
Just make sure you calculate the minimum thread diameter correctly.
I did similar once and somehow got the wrong value, ended up with a nice spiral groove/very truncated thread!
KENAT, probably the least qualified checker you'll ever meet...
Is the picture taken with your phone camera? pretty good.
cheers,
gr2vessels
Yeah Cory that is exactly what I mean. What kind of a bolt is that and where can I get it from?
Timelord you did not understand what I was talking about at all so I wont waste my time explaining it to you. You can a look at the pic that CoryPad has posted instead!
David Landis
The picture is from the Internet.
This bolt is a brake caliper bolt.  Just about every automobile with disc brakes uses these bolts.  You can find them at junk yards or automobile dealership parts departments.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Thank you for the help!
David
