NX 5 progressive die standard parts library
I am working with nx5 progressive die. We have multiple seats and the designers want to share the standard parts library. Is this possible and if so how?
David
David
RE: NX 5 progressive die standard parts library
Generally, NX has in its configuration file a line that points to the location for the files on your local drive. There may also be a custom file location line, there is for CAM files.
You need to change the location to point to a network drive location on each workstation and copy one set of the files to that location.
I am not doing NX support at the moment, so that is why it is only an overview of how to do it.
Ben Loosli
here they are"
PDIEWIZARD_DIR C:\Program Files\UGS\NX 4.0\pdiewizard
PDIEWIZARD_LIB_DIR C:\Program Files\UGS\NX 4.0\pdiewizard
This is what the default dirs are
Setting the variables on each system is the only way I've ever tried to do this.
I did this with moldwizard and I put the whole moldwizard folder under ug on a network drive so everything having to do with moldwizard comes from the same place for everyone.
Hope this helps
Brookey
