Weld drawing annotations
I need to make several welding drawings which have a lot of welds in them. The problem is that if I show all the weld annotations, then the sheet looks cramped and difficult to read. Has anyone encountered such a situation? If yes then what did u do?
David Landis
David Landis
RE: Weld drawing annotations
If already using E/A0 then multiple sheets?
Detailed views/Auxiliary views/showing the same view twice for different annotation...
Or am I missing the point of the question?
KENAT, probably the least qualified checker you'll ever meet...
David
Is each and every weld on your drawing different from the others? If not, you can show two or three typical details, and put the weld annotations on those.
If your drawing is complicated, it sort of indicates that your part is complicated. You are not the only person who will be convenienced by standard details.
JHG
