What forces are applied
I am to test a steering system. What would be the maximum lateral force applied to a rack and pinion component? Or for durability, a constant resistive force applied to a rack or a heavy truck steering gearbox pitman arm. Any manufacture's specifications to reference?
RE: What forces are applied
You could work out what other manufacturers use by reverse engineering their designs, or talking to your suppliers, or figuring out what loads any broken parts you have, saw.
Cheers
Greg Locock
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
The broken, bent, or buckled parts approach would be the most accurate. Admittedly not very scientific, but the steering box should basically outdo anything the tie rods and/or joints can do.
Cheers
Greg Locock
