Sheet metal - Configuration Specific K_Factor
I have 2 configurations of a bent sheetmetal part.
My question : How can I have different K-FActor values for these 2 configs?
Any help on this is appriciated.
Mohan
Mohan
RE: Sheet metal - Configuration Specific K_Factor
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
https://
Cheers,
Anna Wood
SW 2007 SP4.0, WinXP
Dell Precision 380, Pentium D940, 4 Gigs RAM, FX3450
http://designsmarter.typepad.com/solidmuse
http://www.phxswug.com
Jason
SolidWorks 2007 SP5.0
SolidWorks 2008 SP0.1
WinXp sp2 (32 and 64 bit)
For instance, if you are using 7 ga. steel in one configuration and 7 ga. stainless in the other then you just take the ratio of a bend radius (say--.125") to 7 ga. steel thickness (.1793") , which would be .6972, and put that in one column. Then you take the ratio of a bend radius (say also --.125") to 7 ga. stainless thickness(.1875") , you get .6667, and put that in another column. The columns need to be ordered in ascending order from left to right.
If this is practical to do for all the possible configurations and you don't risk having the exact same thickness and bend radius for two different configurations that you would like to assign different k-factors to, then this may work for you. Good luck.
Brian
