Transition between tube and elliptical extrusion
NX3.0: Need help in creating a transition between a tube and an elliptical extrusion. Imagine a rubber hose with a "heat form" to create a flattened section to route through a confined area. Tried sweeping along guide and other simple commands with no luck.
Any ideas? Thanks in advance.
RE: Transition between tube and elliptical extrusion
When you select your section curves make sure you select the same quadrant for each section set and make sure the arrows are pointing in the same direction.
If your section is simply a straight line you may be able to use the 'ruled' command or 'through curves' (both freeform commands).
Unfortunately the company I work for decided not to purchase the studio free form license, which I would assume is where the freeform swept command lives.
I did get (somewhat) representative results using the sweep along guide command, but it's not perfect by any means.
If you can think of anything else, let me know.
Thanks.
Doing it the easy way... You need the tools to do the job
If you have some surfacing capability with you license check whether you can create either a bridge surface or a through curves surface. Either of those are capable of making a tangential transition surface between the two shapes. You would need to extrude the circle and ellipse first so that you can select them for tangency.
Doing it the hard way... May not get the precise result.
This also relies on the axis of the circle and ellipse being aligned. They can be offset relative to each other but your task gets difficult if they're angled.
If you're really out of luck the only thing I can think of is by way of putting you in mind that a 20 square section with a 10 blend on each corner becomes a circular section. So you build a square for the incoming tube and a rectangle the section that becomes the ellipse. Then join them in either direction across the centerline with a transition section made using bridge curves. This would describe a vertical and horizontal section normal to the circle and ellipse, along the axis of the cable. These could each be extruded crossing one another so that when intersected they result in a square cornered transition that meets corner to corner with the square and rectangle. Uniting all three you have a solid that you can blend the corners of. The bridge curves in the transitioning area should ensure that the sides of the transition solid are tangential to the other sections.
When it comes to blending the corners using an edge blend then you'll have to use a variable radius blend and you won't be able to get an ellipse, just a rectangle with radii. Face blend can be used to do a far better job in the transition using tangency controlled blends, but you still get a blended rectangle instead of an ellipse. The only type of blend that approximates your desired result is a soft blend. A soft blend is tangency controlled on both faces and uses the edge as the spine string. In all cases you would need to define four blends one for each corner. Hopefully if you don't have enough licenses to create any surfaces you might get lucky and have the use of soft blends. Otherwise the method I have described may be your best compromise method to approximate the geometry you were thinking of if you lack the licenses to do anything better.
Good Luck
Hudson
Transition Surface might also work in this instance.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
Shape studio is an advanced studio surface license whereas there is a freeform surfacing license also that I think kicks in just above the most basic bundles. Those who work with A-Class surfaces may already know that shape studio does a superior job of building surfaces for industrial design.
I strongly suspect that swept surface is part of the freeform license, but wonder that ruled may not be. The status of through curves would be interesting as it may be slated to replace ruled surface in the future since the functionality overlaps.
Best Regards
Hudson
