sheet Metal Flange NX4
Hi
I sketched 4 sides polygon with 4 corners: 90 deg., 90, 80, 100. I extruded the sketch 1MM and convert it to sheet metal. I tried to create the flange with length 15, angle 90. I expect to get 1 edge 10 degree because it is the same angle from the base. But I got both edge 90 degree. Please help. Thanks.
