Add 2nd leader to diameter dim ?
Is there a way to add a second leader to a diameter dimension? So one dimension can point at two features
Tom
Tom Malinski
http://www.okayind.com/
Dell Prec 670, Xeon 3.8,2GB Ram, Nvidia Quadra FX 3450/4000 SDI
SWorks Pro & PDMWorks 2007 SP3.0
RE: Add 2nd leader to diameter dim ?
I don't know of a way to do that with actual dimensions, but you could "cheat" by using a note which references the dimension and points to multiple places.
cheers
Its not available because per standards, you shouldn't point to two diameters with one dim. Point to one with the correct tol and GD&T, indicating qty.
Chris
SolidWorks 07 4.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 10-07-07)
ctopher's blog
ctopher
I do not dissagree with you, but most of my SolidWorks work is to support a tooling development team. I often create partial tooling prints and in many cases they do not comply with any formal standard because I need to expedite the work. If I used GD&T and other formal practices for this kind of work, I'd be looking for a new job. I'm no stranger to design standards, but I do not have the luxury of time within our fast paced development team. It's kind of like a "less is more" approach. I give them less information and they produce more and faster. In this case I have a tooling assembly that needs WEDM work done to two .0150 dia pins, but not the .0160 pins in the same plate. So I dimensioned one pin to verify its diameter and edited the dim text to spell out the WEDM fit and process instructions, then I just wanted to add an additional leader to point directly to the other pin.
Thanks for your response, I appreciate your comments.
Tom
Tom Malinski
Put in your dimension then highlight the dim. Hold the ctrl down, pick the end of arrow point, drag another line.
Bradley
SolidWorks Premim 2007 x64 SP5.0
PDM Works, Dell XPS Intel(R) Pentium(R) D CPU
3.00 GHz, 5 GB RAM, Virtual memory 12577 MB, nVidia 3400
Bradley
A Star for you. Thanks, thats exactly what I was looking for.
Tom Malinski
What type of dim did you use? For a standard diameter dim, this process does not work for me.
Chris
AutoCAD 06
ctopher's blog
It has to be a manually placed dimension, not an Insert > Model Items one.
cheers
I did a manual placed dim. Did it change for 08?
Chris
SolidWorks 08 0.0/PDMWorks 08
AutoCAD 06
ctopher's blog
I used a Hole wizard hole
Bradley
Don't have 08 loaded yet.
Are you using the single-arrow-leader (note style) dimension or the two-leader-line (goal post) type?
cheers
Smart dimension, then manually add dia dim (single arrow).
Chris
AutoCAD 06
ctopher's blog
This was added to 2007....you can drag the dimension leader to other holes as long as they are the same size.
Jason
SolidWorks 2007 SP5.0
SolidWorks 2008 SP0.1
WinXp sp2 (32 and 64 bit)
Thanks Jason. The "same size" part I missed.
Chris
AutoCAD 06
ctopher's blog
