stone sign base
stone sign base
I have a stone sign (5'wide x 4' tall above grade, 4" thick sandstone) that is being set for a subdivision entrance sign. The City has asked for a stamped and signed foundation for this thing. Bearing capacity and frost depth are easy to acheive. What concerns me is our wind loads (138mph) and how to make sure this thing is connected properly to the fndn so it doesn't blow over. I was thinking they could set the sign, form the foundation, and pour the concrete so its integral with the sign base. They had planned on having it protrude 16" deep into the foundation.
I had mentioned the thought of drilling holes near the bottom of the sign (in the fndn) every 16" and running a #5 bar through horizontally in order to help with the lateral loading, of course the contractor doesn't like that idea.
It would seem having 16" of the sign base embedded in concrete would be suffecient. I assumed I would calc wind load from ASCE 7-05 and make sure there is enough mass in the fndn to resist this overturning moment. I guess the failure would probably occur at the sign base by snapping the stone; this sandstone isn't the toughest stuff, but 4" thick is pretty tough.
Is there a better way to approach this? Any ideas? Am I making a mountain out of a molehill?
Thanks guys...
Thanks guys...
RE: stone sign base
Mike McCann
McCann Engineering
RE: stone sign base
RE: stone sign base
RE: stone sign base
I can't put the strong backs in due to asthetics, both sides of the sign are etched. The contractor says he wants to wet set it, so I think that will work great and be stronger. I looked at wind loads and the OTM and the footer mass will resist the OTM and I think 16" embedded is plenty. I feel pretty good about it..
RE: stone sign base
I would call up a support pad/block under each end of the sign to hold it at the required height. Then you can run reo underneath betwwen the blocks and you know it is going to stay put.
csd
