Resonant column testing
Can any body recommend a lab to do resonant column testing?
RE: Resonant column testing
NVcaster,
Not exactly sure what you are after. Is this some type of non-destructive test?
Jeff
GeoTesting Express, Boxborough, MA.  I've worked with them before--a quality lab.
http://www.geocomp.com/
The test is to determine Dynamic Shear Modulus of Soil (G).  I am also interested in other test methods to determine G and material damping ratio of soil if any body has suggestions.
NVcaster--
I'm assuming that you're talking about laboratory methods?  There are several field options as well.
For low-strain lab determination of G, the res column is the most widely-used, and the only standardized test.  Other options are ultrasonic pulse tests or piezoelectric bender element tests.
For high-strain G, lab options are cyclic triaxial test (ASTM D 3999 or 5311), cyclic direct simple shear (not standardized, but advanced labs--such as GeoTesting Expr--are capable of performing) or cyclic torsional shear test.
Fugro Consultants in Houston, TX has a top notch lab and runs resonant columns routinely
