3D Content Central Search
Has something changed with the way that you access 3DCC through the Design Library tab? Previously, you were able to go to the design library, click on the Search magnifying glass, and pick 3DCC. Now there is no search magnifier, and it takes about 47 clicks to get to 3DCC...moderately annoying.
Anybody else notice this in '08?
RE: 3D Content Central Search
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
Dan
www.eltronresearch.com
Jeff Mowry
www.industrialdesignhaus.com
Reason trumps all. And awe transcends reason.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
Its your choice in the end... as long as you understand its function... I really don't care if someone uses it or not... I disabled the service on my machine.
