Display of Revision of Catia
4
All,
We work on different versions/releases of catia for different client projects on the day and its a common error to open a rev 16 part within a rev 17 envioronment. This is something we wish to avoid so :-
Is there a way of displaying the catia revison ie Rev 16
when catia is opened or having a clear distiction between sessions visually - say a watermark in the background or some floating text like the compass or zoom scale indicator.
Ps I am aware that you can click the help text in the top bar to find out which rev I have active, but its easy to forget to check.
Cheers
Mick
RE: Display of Revision of Catia
First of all, you can try this http://www.catiav5forum.de/wbb3/wbb/index.php?page=Thread&threadID=3855
Then you can change indeed the background in a specific startup screen. All you have to do is replace the C:\Program Files\Dassault Systemes\Bwhateverversionyou have\intel_a\resources\graphic\splashscreens\CATIASplash.bmp with a new bmp file created by you (rename the file if you want).
Fernando
Ferdo is right, or you can simply change the background color for revision 17.
-Hora
4
I think the best way is to tweak the top text line of your Catia window frame:
Browse to your Catia installation folder, e.g.
...\Dassault Systemes\B17\intel_a\resources\msgcatalog\ and look for a file named "CATIA.CATNls". Open that with Wordpad and locate the parameter
 ApplicationFrame.Title        = "CATIA V5";
Add the version number, e.g. "CATIA V5 R17"; save the file and restart Catia. Works perfectly :)
BR
KJamsa
That is a great solution Kjamsa
KJamsa,
Seeing your post - I would like to investigate the top text line further by adding an environment name.
Is this possible?
Most OEMs have individual Release, ServicePack and HotFix levels, but what if you have more than one environment for the same code level . ..
Just a thought.
Scott.
Scott - each install of Catia for OEM has it's own directory.  Your environment points to the particular OEM Version/Config of Catia.  In that particular version/Config of Catia would reside the CATIA.CATNls file.
It is possible to have multiple environments / code level.  For example I use full design mode, CGR Mode, and Selective Mode.
Most of this can be setup under the enviroment manager - Select the environment - File - New From
Derek
Derek,
No and no.
OK lets think of a scenario, we have two installations on the workstation, R16SP8 and R17SP3.
For R16SP8 env name: "OEM1" & "MyEnv"
For R17SP3 env name: "OEM2".
For OEM2 the above scenario, editing the CATIA.CATNls file is OK.
But for the two environments "OEM1" and "MyEnv1" use the same source code, which nullifies your arguement .  .
Scott.
however you can add a additional paths to the catmsgcatalogpath for the two environments put an appropriatly modified version of the CATIA.CATNls file in each and all is well
PeterGuy,
Thanks for pointing me in the right direction - it works well.
Scott.
