Continuous Monitoring Leak Detection
Does anyone have experience using continuous monitoring leak detection equipment in underground pipeline? If so, what/who do you recommend? Acoustic emissions, fiber optic sensing (vapor, liquid), etc...
Length: 1.3 miles
Product: Ethanol
Diameter: 8" underground
Max pres: 100 #
Thanks in advance.
Length: 1.3 miles
Product: Ethanol
Max pres: 100 #
Thanks in advance.
![[gorgeous] gorgeous](https://www.tipmaster.com/images/gorgeous.gif)
RE: Continuous Monitoring Leak Detection
http://virtualpipeline.spaces.msn.com
One of the more "high tech" solution involved (I am going on memory here) acustics whereby a leak will send a sound wave up and down the pipe, and the system will detect these "peaks" and calculated the time differences, and determine where the leak is (to within something like 20 feet). This was particulary interesting to us at the time as our entire line was buried (about 200 km).
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of Eng-Tips Forums?
I looked into the technology about 5-6 years ago, and at that time, the "noise" and false signals were less of a concern than before. As with anything, there can be false "trips" due to unforseen situations. Overall, it is pretty good, especially for underground or "hidden" lines.
If you are interested, you should definitely talke to the vendors and see where the state of their offering is now.
Albert Einstein
Albert Einstein
