Looking for a reliability-type formula
Hi guys
I'm working on a project and I'm trying to put together a cost analysis for some items. I remember in University handling similar problems, but I don't remember the methodology.
Here is what I'm trying to do. Given:
- The age of the unit (say, 1989, so 18 yrs)
- The expected useful life (say 30 yrs)
- The number of units (say 10 units)
- Some accuracy percentage (say 95%),
- some time interval (say, the next 5 years)
I'd like to be able to CALCULATE that X number of units of my 10 are 95% likely to fail within the next 5 years.
thanks everyone.
dan
RE: Looking for a reliability-type formula
Hi Dan,
Not sure about your question but perhaps a life cycle costing analysis will provide a better financial picture.
+R
Do you have the MTBF?  How are you going to do the analysis without that?
But, in any case, without some additional data, I don't see that you can your desired answer.  Prognostication is horrifically non-deterministic.  You need to know hours-on, operating temperature, vibration environment, etc, to come up with a mean value, but even then, you'd need statistic history to know how much variance there is in the actual times to fail.
TTFN
What if you used the number of units that have failed since 1989 to estimate a failure rate (say, 2 units over 18 yrs = 0.111 units per year)?
And we'll make up a confidence interval, say 99% of units have an expected useful life of 30 years.
My gut says that Poisson can be modified to solve for this type of problem, but its been 8 years since I did any real probability problems.
With regards to accuracy, we have some flexibility since this is not a life safety issue. If we say that we are 95% confident that 4 units will fail, and instead, 5 fail, it is acceptable to attribute the variance to a poor maintenance program.
Thanks everyone for your help.
With the added information, can this type of problem be modeled with a single formula?
If so, what is it?
