Problem with solver constraints
Can anyone help with this solver VBA code? basically it refuses to set the constraint for cells(106,3+chkcount) to 1
****solveradd cellref:=Sheet1.Cells(106, 3 + chkcount), relation:=3, formulatext:=1***
If I change this to zero it works but not 1... Doesn anyone know why? I thought it was becasue the cells were zero and that would make it illegal so I changed em to one before the line is done but still it doesn't add the constraint.
If CheckBox1.Value = True Then
        total = TextBox1
        Sheet1.Cells(116, 3) = TextBox1
        For chkcount = 1 To Sheet2.Cells(20, 9)
            Sheet1.Cells(106, 3 + chkcount) = 1
            If chkcount = 1 Then
                solveradd cellref:=Sheet1.Cells(106, 3 + chkcount), relation:=1, formulatext:=100 / TextBox1
                'solverchange cellref:=Sheet1.Cells(106, 3 + chkcount), relation:=1, formulatext:=100 / TextBox1
            Else
                solveradd cellref:=Sheet1.Cells(106, 3 + chkcount), relation:=1, formulatext:=Sheet1.Cells(106, 3 + chkcount - 1)
                solverchange cellref:=Sheet1.Cells(106, 3 + chkcount), relation:=1, formulatext:=Sheet1.Cells(106, 3 + chkcount - 1)
            End If
        Next chkcount
        solveradd cellref:=Sheet1.Cells(106, 3), relation:=3, formulatext:=0
        'solverchange cellref:=Sheet1.Cells(106, 3), relation:=3, formulatext:=0
RE: Problem with solver constraints
I don't understand what is actually being done with the code shown, are you saying that solver gets confused between sheets?
OK I have re-done my code, Im sorry but I didn't understand what was happening with what was suggested by yourself on the other page, this is my new code. It works perfectly but for some reason when I make a few changes to the cells within this same segemnt of code, solver just sits there but reports that everythin is "optimal" also the solver reset doesn't seem to be working propperly at the end. My brain is really starting to hurt now!
Cells(106, 3) = TextBox2
        yearcount = TextBox2
        preasureyr = "R111C12:R111C" & 11 + TextBox2
        totalyrs = "R111C11:R111C" & 11 + (TextBox2 * 2)
        SolverOk SetCell:="R108C34", MaxMinVal:=2, ValueOf:="0", ByChange:=totalyrs
        SolverAdd CellRef:="R111C11", Relation:=3, FormulaText:="0"
        SolverAdd CellRef:=preasureyr, Relation:=1, FormulaText:="R32C3"
        SolverSolve UserFinish:=False
        Sheets("Sheet2").Select
        Application.ScreenUpdating = True
        solverreset
