PDM-toolbox
PDM-toolbox
i created a gear by toolbox then saved this part as a part file according to my filename structure. And my pdm automatically marks this part as toolbox(library part). I want to see this part in my project like other parts.
Can any body help me, how to show this part like others.
with all respect.
solidworks 2007 sp5
with all respect.
solidworks 2007 sp5
RE: PDM-toolbox
This will essentially make the part look like a "regular" part to PDM, so you should now be able to check in your gear.
RE: PDM-toolbox
RE: PDM-toolbox
C:\Program Files\SolidWorks\Toolbox\data utilities\sldsetdocprop.exe
can be used to remove the library part tag.
Eric
RE: PDM-toolbox
But i failed. i used the "sldsetdocprop.exe". Yes they lost their pdm-toolbox properties, but now they are "standart library file". They are "not revision managed" standart library files.
I need to check in them as "revision managed" normal project files.
with all respect.
solidworks 2007 sp5
RE: PDM-toolbox
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
RE: PDM-toolbox
Eric
