Induction VAV Vs Normal VAV systems
Guys,
I recently learned that the induction type VAV systems using low off coil temperatures are becoming popular as you can use lower air flows and therfore smaller air ducts .Is it more efficient than a normal VAV system?I guess there will be an energy penalty on the chiller due to lower chilled water temperatures required?
RE: Induction VAV Vs Normal VAV systems
http://www.trane.com/Commercial/DNA/View.aspx?i=5
