Staad foundation Mat analysis
Hello!
I'm pretty new using staad foundation, and when I try to run an analysis for a mat foundation (I have followed the example in the tutorial to practice) I obtain a pop-up windows telling that : Analysis results are not available.
I can see under the process that the loads are not found. But I have well input the loads and I can see them.
Maybe I miss an operation... if someone have already be in this situation, or have an idea of what I do wrong...
Thanks a lot!
Thanks a lot!
RE: Staad foundation Mat analysis
That error message normally means that the program could not analyze the mat foundation. There could be many reasons behind this
1) Your soil property is not defined or assigned
2) You have created load cases but not assigned to the current job
If you send your file to STAAD technical support they should be able to give you the solution. Normally they are very quick to answer.
