Looking for a spec that matches this composition
I am reverse engineering a part that has the following chemical composition results from testing. Ideally I am looking for a north american spec but the original could be european.. Any suggestions (guesses??)
Carbon 0.31
Manganese 0.412
Sulfur 0.01
Phosphorous 0.012
Silicon 0.312
Nickel 3.38
Chromium 1.34
Molybdenum 0.439
Copper 0.084
Aluminum 0.007
Vanadium 0.007
Iron Balance
Carbon 0.31
Manganese 0.412
Sulfur 0.01
Phosphorous 0.012
Silicon 0.312
Nickel 3.38
Chromium 1.34
Molybdenum 0.439
Copper 0.084
Aluminum 0.007
Vanadium 0.007
Iron Balance
RE: Looking for a spec that matches this composition
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Ed, I have several components made from the material. I don't have all the material properties but they are all through hardened to 32-36HRC, 37-38HRC or 36-38HRC.
Any comments on the effect on the material with regard to material properties like fatigue or cold weather toughness of the different carbon and moly percentages between 9310 and 32NICrMo14-5??? ie are they close enough in properties that 9310 could be argued as an equivalent?
HY100 really is the closest in terms of composition, properties, and end use.
Cory
