Seal Slab Concrete Compressive Test
The general notes issued with a project called for a "seal slab" to be used on any foundation excavation left open more than 24hrs. The material callout is simply 2,000psi lean concrete. The onsite QA/QC rep for the project is requiring concrete cylinder breaks to prove the seal slab material strength prior to acceptance and continuation of the structural concrete pour for the foundations.
Has anyone heard of requiring compressive tests for seal slab concrete?
RE: Seal Slab Concrete Compressive Test
The situation of requiring the testing is coming from a third-party quality control/field inspection service company. I do not believe they are specialists in Civil inspection and testing. This work is being performed in the petrochem field.
JAE - I agree
